animated header
Thread begun 3/28/2019 5:01 am by Jamie | Last modified 4/01/2019 10:50 am by Ray Borduin | 1874 views | 4 replies |
Jamie
animated header
Hey Ray
Just wondering if you wouldnt mind taking a look at this site am working on please. On breakpoints below 768, if you open the menu and then scroll down a tiny bit the menu starts jiggering around (have attached a video) and cant work out what is conflicting to make it do that. The test page is http://bit.ly/2JMoeOw
Many thanks
Jamie
It looks like you have a javascript that changes a header class and hides and shows the "back to top" button. Somehow changing the classes in one or both of those is causing the condition to change so that it starts thinking it should remove it, and then that causes an infinite loop of adding and removing the button and class to adjust the header.
I'd need FTP access to play with it and find a fix.
Jamie
thanks Ray...site def attached
The issue was with the scroll javascript code you were using to add a "smaller" class to the header if the page is scrolled more than 100 pixels down.
The issue is that adding the "smaller" class decreases the page size by 30 pixels and that causes the page scroll position to change. So if you were scrolled between 100 and 130 pixels down the page then the "smaller" class was added and the page shrinks causing the scroll position to decrease by 30 pixels so you are now between 70 and 100 pixels scrolled, which causes the "smaller" class to be removed and this causes an infinite loop.
I fixed the issue by combining your code for the "back to top" and "smaller" class into a single function and added a range so that it displays if you are scrolled more than 100 pixels down, but doesn't remove unless you are less than 70 pixels down. This allows the 30 pixel page size change to not cause an infinite loop.
I also added a timout delay in the scroll function because that is good practice in general since scroll can be called hundreds of times in a single scrolling event and you really only want your function called one time once the scrolling is complete.
All of my changes were in the includes/fixed/scripts.php page.
Jamie
thanks Ray- thats brilliant
