Importing Excel worksheets into Power CMS
Thread begun 3/22/2019 10:36 am by kg_nsa395746 | Last modified 3/22/2019 12:25 pm by Ray Borduin | 959 views | 3 replies |
kg_nsa395746
I want the capability of importing an Excel worksheet table into Power CMS. Is it possible to do this? I can import the worksheets directly into Dreamweaver, but don't know if this can be done when I set the region up in Power CMS. I don't want the worksheet to be a downloadable document. One column of cells has active links to PDF files.
I'm not sure what you mean exactly by "import excel spreadsheet into powerCMS". You want to copy and paste the contents? You want to use a file upload and display it?
kg_nsa395746
What I've done in Dreamweaver is use the Import/Tabular Data to bring in the data. If we can copy and paste the rows/columns into a Power CMS region, that would work too. Will the file upload option display the actual data from the worksheet along with links? I'm searching "in the dark" for a solution. I currently have a table setup in the page, but periodically we need to archive some of the data to another page. As it's set up now, we have to reenter all the data into the new page. Very time consuming.
It looks like there is a copy/paste from excel option that can be added to your html editor:
https://ckeditor.com/docs/ckeditor4/latest/examples/pastefromexcel.html
I'm not sure if it carries over links. If you can give me FTP access and a URL to reproduce the issue then I can try to enable that option in your editor.
