JQuery Question
Thread begun 3/12/2019 12:36 pm by vernon webb | Last modified 3/15/2019 11:49 am by Ray Borduin | 3593 views | 10 replies |
vernon webb
JQuery Question
Was wondering if someone could help me with the following. I am using the below code to copy the value of a select (bandName) to a form field (keywords) and it works fine. However I was hoping to also append the data from a different select (vID) to end but it over writes whats there. Is there as way to append as opposed to over writing?
<script type='text/javascript'>
$(function() {
$('#bandName').change(function() {
var x = $(this).find('option:selected').text();
$('#keywords').val(x);
$(function() {
$('#vID').change(function() {
</script>
$(function() {
var x = $(this).find('option:selected').text() + $("#vID").find('option:selected').text();
$(function() {
var x = $("#bandName").find('option:selected').text() + $(this).find('option:selected').text();
</script>
vernon webb
Works great. One minor issue. When the vID is appended it doesn't leave a space between words, it combines the last and first words. How do I add the space?
You can add the space in the code:
$(function() {
var x = $(this).find('option:selected').text() +" "+ $("#vID").find('option:selected').text();
$(function() {
var x = $("#bandName").find('option:selected').text() + " " + $(this).find('option:selected').text();
</script>
vernon webb
How can I do the same for a text field?
just use:
$("#textfieldID").val()
instead of:
$("#selectFieldID").find('option:selected').text()
vernon webb
Yeah I'm not sure I got any of this right:
$(function() {
$(function() {
$(function() {
$("#specialGuest").val(function() {
</script>
I'm not exactly sure what you are trying to do, but I think it is probably closer to:
$(function() {
var x = $(this).find('option:selected').text() +" "+ $("#vID").find('option:selected').text() + " " + $('#specialGuest').val();
var x = $("#bandName").find('option:selected').text() + " " + $(this).find('option:selected').text() + " " + $('#specialGuest').val();
$("#specialGuest").blur(function() {
var x = $("#bandName").find('option:selected').text() + " " + $("#vID").find('option:selected').text() + " " + $('#specialGuest').val();
</script>
Maybe tell me what you are trying to do in plain English so I can understand what the code should be doing. I see you are trying to do something with the specialGuest text field, but I can't tell what you want it happen when the value changes.
vernon webb
I did explain it above but will again here.
The above ones work, the ones you provided.
$(function() {
$(function() {
</script>
But now I have a field called specialGuest, it's just a text field and I want the value of that field to also populate into the keywords field after it's typed in.
The only details above were:
"How can I do the same for a text field?"
Which was a bit light on specific details.... I've updated the code example above to do what you describe.
