Insert Multiple Records
Thread begun 2/06/2019 9:56 am by LWat85283715 | Last modified 2/06/2019 12:21 pm by Ray Borduin | 3808 views | 7 replies |
LWat85283715
I am trying to insert multiple records from a form. I can get it to insert the records but, it is not looping through the number of designated data elements selected. What I need for it to happen is for every district selected, it will add a record for every data element selected. Attached is a screenshot of the page.
Here is the insert code:
if (isset($_POST["submit"]) || isset($_POST["submit_x"])) {
$element = $_POST['data_elementID'];
foreach($element as $name=>$value) {
$InsertQuery = new WA_MySQLi_Query($sdpc_i);
$InsertQuery->Action = "insert";
$InsertQuery->Table = "district_data_elements";
$InsertQuery->bindColumn("districtID", "i", ((isset($_POST["districtID"]))?$_POST["districtID"]:"") , "WA_NULL");
$InsertQuery->bindColumn("softwareID", "i", "".((isset($_POST["softwareID"]))?implode(",",$_POST["softwareID"]):"") ."", "WA_NULL");
$InsertQuery->bindColumn("data_elementID", "i", ((isset($_POST["data_elementID"]))?$_POST["data_elementID"]:"") , "WA_NULL");
$InsertQuery->saveInSession("");
$InsertQuery->execute(); }
$InsertGoTo = "manage_agreements_state.php?state=".$_GET['state'] ."&districtID=".$_GET['districtID'] ."";
if (function_exists("rel2abs")) $InsertGoTo = $InsertGoTo?rel2abs($InsertGoTo,dirname(__FILE__)):"";
$InsertQuery->redirect($InsertGoTo);
Here is the form code:
<form method="post" enctype="multipart/form-data">
<div class="row">
<div class="col-xs-5">
<select name="from[]" id="search" class="form-control" size="15" multiple="multiple">
while(!$category->atEnd()) { //dyn select
<option value="<?php echo($category->getColumnVal("data_elementID")); ?>"><?php echo($category->getColumnVal("element_name")); ?></option>
$category->moveNext();
} //dyn select
$category->moveFirst();
</select>
</div>
<div class="col-xs-2">
<button type="button" id="search_rightAll" class="btn btn-block"><i class="glyphicon glyphicon-forward"></i></button>
<button type="button" id="search_rightSelected" class="btn btn-block"><i class="glyphicon glyphicon-chevron-right"></i></button>
<button type="button" id="search_leftSelected" class="btn btn-block"><i class="glyphicon glyphicon-chevron-left"></i></button>
<button type="button" id="search_leftAll" class="btn btn-block"><i class="glyphicon glyphicon-backward"></i></button>
</div>
<select name="data_elementID[]" id="search_to" class="form-control" size="15" multiple="multiple">
</select>
</div>
</div>
<p>&nbsp;</p>
<h4>Please select the district(s) that use this resource that you would like to assign these data elements to:</h4>
<div class="row">
<select name="from[]" id="search2" class="form-control" size="15" multiple="multiple">
while(!$districts_selected->atEnd()) { //dyn select
<option value="<?php echo($districts_selected->getColumnVal("districtID")); ?>"><?php echo($districts_selected->getColumnVal("district_name")); ?></option>
$districts_selected->moveNext();
} //dyn select
$districts_selected->moveFirst();
</select>
</div>
<button type="button" id="search2_rightAll" class="btn btn-block"><i class="glyphicon glyphicon-forward"></i></button>
<button type="button" id="search2_rightSelected" class="btn btn-block"><i class="glyphicon glyphicon-chevron-right"></i></button>
<button type="button" id="search2_leftSelected" class="btn btn-block"><i class="glyphicon glyphicon-chevron-left"></i></button>
<button type="button" id="search2_leftAll" class="btn btn-block"><i class="glyphicon glyphicon-backward"></i></button>
</div>
<select name="districtID[]" id="search2_to" class="form-control" size="15" multiple="multiple">
</select>
</div>
</div>
<input type="hidden" name="softwareID[]" id="softwareID" value="<?php echo $_GET['softwareID']; ?>" />
<br><br>
<input type="image" src="images/save.png" name="submit" id="submit" alt="Save" />
</form>
Please attach the actual page instead of copy and pasting the contents in the future so that I can open the page in Dreamweaver to analyze it.
In your bindings you chose the CSV version of the binding instead of the Array version. You need to use the Array version to initiate the multiple update.
If you can provide a URL and FTP access then I could fully debug and try to help figure out if any other updates are necessary.
LWat85283715
Sure. Attached is the actual file. Thanks for your help.
LWat85283715
It is a login restricted page. My company doesn't allow others to FTP but, I have TeamViewer if needed.
Try updating:
$InsertQuery->bindColumn("softwareID", "i", "".((isset($_POST["softwareID"]))?$_POST["softwareID"]:"")  ."", "WA_NULL");
LWat85283715
Sorry but, that didn't work. It added only 2 rows and there should of been 4.
I'm not sure what the issue might be. I don't offer free screen sharing support to help build applications unless a bug is identified in our tools.
I could set up a premier support ticket to look into this with you over the phone with a screen sharing session, but if there isn't an issue with the extension I'd have to charge you for it.
If you are comfortable with this, then give me a call or post a phone number in the private area where I can call you and we can set that up.
