MySQLi recordset not accessible to any other third-party extensions
Thread begun 12/28/2018 1:19 pm by Mohammed Aji Wajiro | Last modified 12/28/2018 3:47 pm by Ray Borduin | 1501 views | 3 replies |
Mohammed Aji Wajiro
Since my update to DataAssist with MySQLi, all my other third-party extensions (DWzone and DMXZone) could not recognize recordsets. Those extensions are also crucial in all my web developments. Is there any workaround? Thanks.
They probably don't work with MySQLi. What functionality are you attempting to add, we may be able to help you find something that will work.
Mohammed Aji Wajiro
Most of the third-party extensions i use were to supplement functionalities that are missing from the databridge. For example, importing and exporting to/from various formats like pdf, csv etc as well as bunch of other extensions that relies on recordsets. DWzone for e.g. has a MySQL to MySQLi converter that converts codes generated by dreamweaver's native recordset to MySQLi's version while maintaining the structure but doesn't work on databridge's. Any workaround and perhaps an extension that will enable me access recordsets from those extension will save me the nightmare. Thanks.
Unfortunately no. Our mysqli code relies on our libraries and syntax which is improved and much cleaner than the native dreamweaver versions. I don't think there is any way to make other extensions work with it other than to update those extensions which is out of our control.
Creating a csv from a recordset is very simple, so that is something I could help you with manually, but pdf creation is more tedious. I could probably help you do the conversion in a paid premier support ticket so you could do it in future applications.
