PHP 5.3 Released, Causing Issues
Thread begun 9/10/2009 2:55 pm by John Langer | Last modified 9/14/2009 1:23 pm by Jason Byrnes | 5153 views | 5 replies |
John LangerBeta Tester
On my testing local server using PHP 5.3, I get the following error on all apges where the menu should be.
Deprecated: Function split() is deprecated in C:\wamp\www\testingsite\CSSMenuWriter\cssmw\menu.php on line 16
This is not a problem as I also have use of PHP 5.2.9 and my live server is also 5.2.9 (For how much longer though I don't know).
Just thought I'd raise the issue so you know.
I've posted here but I suppose the problem is really with CSS Menu Writer?
Jimmy Wu
This is a known issue with CSS Menu Writer. If you change the split function to the explode function, the menus should work fine. Thanks for reporting this issue.
Originally Said By: Jimmy Wu
Is there an example bit of code you could publish for us "point and clickers"? Or is it just a question of changing the word "split" for "explode"?
I'm just concerned in case my host decides to upgrade PHP any day soon. Perhaps as known "cures" come up, you could publish them on a dedicated thread. Just a thought.
It's just changing split to explode.
In the menu.php page, line 16 is:
$WA_ddsArray = split("/", $WA_thisFile);
it needs to be changed to:
$WA_ddsArray = explode("/", $WA_thisFile);
Thanks Jason, that sounds straight forward enough (even for me).
you're welcome.
