hiding content already set to display none
Thread begun 12/19/2018 4:36 am by Jamie | Last modified 12/20/2018 4:12 pm by Ray Borduin | 1290 views | 3 replies |
Jamie
Hey Ray
On this site http://www.vanessaconyers.com on the desktop version there is a drop down navigation under 'the collections' and 'shop online' - the top level are also clickable which then take you through to a category results
On the mobile version (< 768px) the navigation currently works the same way but the client wants to only have the top level nav point (the collections, shop online etc) to show and not the drop down elements.
The fact that by definition the sub menu is a drop down and the <ul> container is set to display:none am unsure how to stop the sub menu from being displayed at the lower breakpoints
tia
Jamie
I don't fully understand the question... but I think the answer is probably to add a class to elements you want to change at a particular break-point and then use that class to display or not in the media query.
Jamie
thats the problem though. Because its a drop down, am already using display:none for the containing <ul>. If you use visibility:hidden it hides the content but retains the space that it takes up
I suppose I am just trying to figure out how to stop the dropo down from triggering in the 768 and below break points
If you use the important attribute in your responsive CSS like:
.class {
style: display:none !mportant;
Then it won't display even on hover.
