Saving data in a new way.
Thread began 11/20/2018 11:24 pm by Kumel | Last modified 11/21/2018 4:36 am by Ray Borduin | 201 views | 1 replies |
Kumel
Hi Webassist Team,
My new client has a bunch of data on MySQL. Most of the data are arrays.
Example: Every product has multiple categories; thus they have saved "ProductCatID" as: "1,2,3,6,7..." & so on.
Meaning a product has multiple categories with cat id as mentioned above.
I never used such way to save data. But used a different table to save them & used relational table concept.
Now I need to use existing data itself & create a dashboard from them to manage it.
In this scenario, i can create for adding data into it, but what about in case of in edit product page & search product page?
Will search work within an array?
It is probably possible, but it will be complicated and inefficient. The better solution is to normalize the tables into proper relational table design.
Read: https://dba.stackexchange.com/questions/112408/join-with-comma-separated-values-in-sql-server
