showing content based on column
Thread begun 11/15/2018 7:09 am by Jamie | Last modified 11/22/2018 10:28 am by Ray Borduin | 3711 views | 8 replies |
Jamie
Hey Ray
On the attached page, I have a recordset (Downloads) repeated several times starting at line 12 to show depending on which DownloadType and just wondering if there is a better way to effect the same result?
Also, and further down the page (starting at line 99) a box which I want to display downloadable pdf's chronologically - so far have got that for 2018.
There are other downloads which have year dates (2017, 2016 etc) and if there are downloads with a year date I somehow need to get further boxes uses the same styling to then list the content in those subsequent boxes.
I hope that you're able to make sense of that?
Cheers
Jamie
You could clean it up a little by replacing lines 11-51 with:
$Downloads
= new WA_MySQLi_RS("Downloads",$DBConnection,0);
$Downloads->setQuery("SELECT * FROM download WHERE DownloadType = ? AND Live = 1 ORDER BY DownloadDate ASC");
$PageContents->bindParam("i""".($PageContents->getColumnVal("ServicesID"))  ."""-1"); //paramOffersID
$Downloads->execute();
Your code that starts on line 99:
<?php if ($Downloads->TotalRows 0) { // Show if mysqli recordset not empty ?>
        <div class="container downloadWrapper">
          <h3 class="heading-1">2018</h3>
          <div class="container downloadContainer">
$wa_startindex
0;
while(!
$Downloads->atEnd()) {
$wa_startindex $Downloads->Index;
              <a class="link-text downloadLnk" href="downloads/<?php echo($Downloads->getColumnVal("DownloadFile")); ?>" target="_blank"><?php echo($Downloads->getColumnVal("DownloadTitle")); ?><br>
              </a>
  $Downloads
->moveNext();
$Downloads->moveFirst(); //return RS to first record
unset($wa_startindex);
unset(
$wa_repeatcount);
          </div>
        </div>
        <?php // Show if mysqli recordset not empty ?>
You could update to something like:
$showYear
$wa_startindex
0;
while(!
if ($showYear != date("Y"strtotime($Downloads->getColumnVal("DownloadDate")))) {
          <h3 class="heading-1"><?php echo(date("Y"strtotime($Downloads->getColumnVal("DownloadDate"))); ?></h3>
              </a>
$showYear date("Y"strtotime($Downloads->getColumnVal("DownloadDate"));
          </div>
  $Downloads
->moveNext();
unset(
$wa_repeatcount);
        </div>
Jamie
thanks Ray - 1st answer exactly what I was looking for but completely forgot how to do
2nd on eis almost there but each month is showing in its own year container when am trying to get all the months from 2018 in same container, all the ones from 2017 in same container etc
At the moment it looks like this: http://clients.motley.site/hbpc/pc/parish-council-agendas updated page attached
You have an extra semi-colon at the end of lines 75 and 85... remove those and it should work.
Jamie
thanks Ray.... almost there. The containers for each available should look like this http://prntscr.com/liu8ez
It looks like the first record in each is falls within the <div> but then the others dont. http://prntscr.com/liu9x8 reed is the first record and blue are the subsequent
Also, how would you sort the year DESC and then the records by ASC?
SELECT * FROM download WHERE DownloadType = ? AND Live = 1 ORDER BY YEAR(DownloadDate) DESC, DownloadDate ASC
And I think I see the error in my logic... try this:
$showYear
$wa_startindex
0;
while(!
if ($showYear != "") echo("</div></div>");
?><div class="container downloadWrapper">
            <h3 class="heading-1"><?php echo(date("Y"strtotime($Downloads->getColumnVal("DownloadDate")))); ?></h3>
              <a class="link-text downloadLnk" href="downloads/<?php echo($Downloads->getColumnVal("DownloadFile")); ?>" target="_blank"><?php echo($Downloads->getColumnVal("DownloadTitle")); ?></a>
$showYear date("Y"strtotime($Downloads->getColumnVal("DownloadDate")));
  $Downloads
->moveNext();
unset(
$wa_repeatcount);
?></div>
            </div>
Jamie
thats brilliant and almost there - thanks so much
The only issue is that the first year shows fine, then the subsequent one(s) dont have any styling nor does the container separate so that each year is in it own as per http://prntscr.com/liu8ez
http://clients.motley.site/hbpc/pc/parish-council-agendas - updated page attached
I updated the code in my last post. Give that a try.
Jamie
superb. many thanks
