I can not find Dynamic Web Charts anymore!
Thread begun 11/13/2018 6:36 am by Jonas | Last modified 11/14/2018 10:25 am by Ray Borduin | 1502 views | 2 replies |
Jonas
What has happened to Dynamic Web Charts? I can not find it in the WebAssist menu anymore.
The only thing I can find about this is under Server behavior -> WebAssist -> Dynamic Web Charts -> Reset to first record.
It has been removed and deprecated. It used Flash to render the charts so it isn't really viable. Adobe will fully drop support for flash in 2020, so we had to move on.
I've considered adding a new charting solution, but I'm still investigating the right one to use and it will take quite a bit of development to add back with a whole new code base.
In my experience it was a relatively uncommon feature, so I was considering leaving it out entirely moving forward as well.
Jonas
It is certainly good that you think so (Flash is no longer up-to-date), but sad to hear you have no option.
I have not had to use this earlier, but the project whose prototype I'm working on is supposed to have dynamic charts. So, I had hoped that this was still working.
I really hope you're going to create a new version (soon) that writes HTML5 instead.
