Not connecting properly to server
Thread begun 10/29/2018 5:19 pm by Steve | Last modified 10/30/2018 3:53 pm by Ray Borduin | 2553 views | 6 replies |
Steve
Not sure why this error is showing. I can test the connection without error and you can see from the screenshot it's a very simple query with no errors.
"MySQL server version" has never came up before so not sure where this is coming from...
MySQL Error#: 1064
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'b64:U0VMRUNUIG5ld3MuKiBGUk9NIG5ld3MKV0hFUkUgMCA9IDE=' at line 1
It sounds like your MM_ServerScripts folder is out of date. You can try clearing it with Site->Advanced->Remove Connection Scripts.
It could be that another extension installation overwrote them. You may need to reinstall DataBridge to get the current version.
Steve
That did not work either.
Removed remote scripts.
Reinstalled DataBridge
Tired to use Bindings to return columns from query. Error as shown.
Steve
Interesting that we can add a new query but just the Bindings panel fails to allow population of query results...
Steve
And now it's working....
We updated the MM_ServerScripts to pass encrypted queries. This is because more and more servers have ModSecurity rules that prevent posting of SQL statements. The errors you got were showing the encrypted data being passed by dreamweaver, but not being unencrypted by your MM_ServerScripts.
Somehow they must have been out of date and just miraculously got updated since they are working now.
Steve
I created a new Query, then retested, which seems to have caused the correction.
