Security Assist errors
Thread begun 8/29/2018 9:07 am by jhaa32156951 | Last modified 9/01/2018 1:48 pm by Ray Borduin | 4880 views | 16 replies |
jhaa32156951
Mac OS High Sierra 10.13.6
Dreamweaver CC - 18.2
Testing on live server - php 7 iPage hosting
DataBridge beta 2-2-0
Having 2 problems with the DataBridge 2.20.
Fist problem may be a Dreamweaver problem. When trying to make a new db connection through the WA database panel I am getting this error:
“ Your php server doesn’t have the MySQL module loaded or you can’t use the mysql_(p)connect function”
Second problem: Security Assist pages.
Login page works correctly allowing me to login to a members section.
forgotpassword.php - am getting an internal server error.
The connection error is most likely a problem with your testing server and the Site URL field.
I'd have to debug the issue with the forgot password page. If you give me FTP access and steps to reproduce then I can take a look and try to figure it out.
jhaa32156951
Here is login for ftp etc.
Don't exactly understand the answer to my first question.??
Please send a screenshot of your testing server settings from your Dreamweaver site settings and I might be able to spot the first issue. It is probably just that your testing server url needs https:// instead of http:// in the front.
The forgot password page error is because you haven't uploaded the webassist/email folder contents to the live server. Please try putting those files and see if that fixes the problem.
jhaa32156951
Ok here you go.
I've added more files that were missing. I think the SecurityAssist wizard may not be adding them properly, so I'll look into that issue.
jhaa32156951
Thanks Ray!
Your connection works for me with the site I defined using your settings. I'm not sure why it isn't working for you.
Have you tried going to: Site->Advanced->Remove Connection Scripts
If that doesn't work, post a US phone number or Skype contact information and I will do screen sharing with you to debug and fix this problem.
jhaa32156951
My connection script works for me as well . What doesn't work is adding a new conncetion with WA database panel.
