Connection Errors
Thread begun 7/26/2018 6:23 am by rob294118 | Last modified 7/27/2018 9:39 am by Ray Borduin | 1351 views | 4 replies |
rob294118
Connection Errors
I'm now getting errors on my Contact page and I can't add items to my cart. I'm getting this error on my contact page:
Deprecated: mysql_pconnect(): The mysql extension is deprecated and will be removed in the future: use mysqli or PDO instead in /hermes/walnaweb05a/b395/moo.eloiseinccom/EloisePetAccessories/Connections/PowerStoreConnection.php on line 9 Warning: session_start(): open(/var/php_sessions/sess_435888664fd616dc2a8e30aa5344a818, O_RDWR) failed: No such file or directory (2) in /hermes/walnaweb05a/b395/moo.eloiseinccom/EloisePetAccessories/WA_eCart/WA_eCart_Definition_PHP.php on line 480 Warning: session_start(): Cannot send session cache limiter - headers already sent (output started at /hermes/walnaweb05a/b395/moo.eloiseinccom/EloisePetAccessories/Connections/PowerStoreConnection.php:9) in /hermes/walnaweb05a/b395/moo.eloiseinccom/EloisePetAccessories/WA_eCart/WA_eCart_Definition_PHP.php on line 480
Please help.
Thanks.
You can turn off deprecated messages in your php.ini file or on the page itself in order to get rid of these warnings. They aren't actual errors.
rob294118
There is no php.ini file. When I create one, now I get an "500 Internal Server Error". Also, I used to have a contact form on the contact us page but it does not show up. I also can't add anything to the cart. This site has been up for years. This just started happening. I'm using Powerstore 2 I think.
I went to /PowerGallery and it showed a server error:
There is a problem with session management on your server. Contact your hosting provider to fix the problem. For more information, please refer to the PHP manual.
How do I login to the admin? It's been a long time.
Please post one issue at a time. I'm not sure which question to answer.
Ask your hosting company how to turn off deprecated messages. You usually can't just create a php.ini file and have that work.
That could be another php.ini problem and a bad session.save_path folder.
If session values aren't working, then you won't be able to log into the admin.
rob294118
This post has been deleted.
