Blank Page and Universal Email Issues
Thread begun 6/06/2018 7:12 am by vernon webb | Last modified 6/12/2018 2:24 pm by Ray Borduin | 5553 views | 17 replies |
vernon webb
When I open this page it comes up blank. I manually readded the update as it wasn't showing and I'm not sure if the Universal Email has anything to do with it, however, when I open it up all the values are blank (meaning un-populated)
You have the old version of Universal Email on the page and it refers to the two include files:
<?php require_once("../webassist/email/mail_php.php"); ?>
<?php require_once("../webassist/email/mailformatting_php.php"); ?>
Those files aren't uploaded to your server. You should be able to update it to the new version and it won't use those includes anymore.
vernon webb
OK so I uploaded those and the page works but I cannot edit as when I open the behavior all is blank still.
The values are in:
../webassist/email/waue_add_MGR_RATING_1.php
It looks like you are missing that file as well. You will have to put it in the correct location before you can open the UE server behavior.
vernon webb
I got it to open, edited it, now back to 500 error
It didn't migrate your mail log settings properly. I've re-applied the email after updating the log settings and that seems to have fixed the problem.
vernon webb
Sorry same problem here
I copied and pasted the updated email log bindings from the insert page and that seems to have fixed it.
vernon webb
OK looking at the code here I see that it is still looking for the connect connADINS (line 83) to which is connecting to an email_log table. However if I try to edit that, using the server behavior, it allows me to change the connect to the proper one (connIO_i) but doesn't allow me to change the table...
It seemed to work for me. I updated the connection and it would allow me to change the table. What happens when you try.
