Javascript errors when creating a new form
Thread begun 5/17/2018 12:37 pm by sandy170299 | Last modified 5/18/2018 10:42 am by Ray Borduin | 3961 views | 9 replies |
sandy170299
I'm consistently getting this error when trying to create a new form. Even in a brand-new, blank site. I deleted my Dreamweaver cache, FYI...
Thank you.
sandy170299
P.S. I am using the BETA version of Data Bridge, v. 2.0.0.
Please download and install the latest version updated yesterday. This issue was already reported and should be fixed.
sandy170299
Where is the link for downloading the latest extension? Thanks.
Follow the link on the top of the site and it will lead you to the forum post with all of the downloads:
http://www.webassist.com/forums/posts.php?id=40942
sandy170299
Version 2.0.0. That's what I had downloaded an hour ago, and I still got errors. It's not saving any of the info on the Form Function tab of the Form Builder.
Wait are you still getting the first error, or did that fix it? I'm confused.
The second issue appears to be a problem with how the from value is encoded on the page.
To fix that, delete that line of code and open the Email Server Behavior and set it there instead. The from value really shouldn't be set to the entered value from the form because it will effect the deliver-ability. Instead set the FROM address to a valid email address on your web server that ends with the same @domain.com address that your website uses. Then set the Reply-To address to use the form element value instead.
sandy170299
OK - it's working now. So, in the form wizard, I should not enter any of the data on the Form Function tab, but enter it in the email server behavior instead?
It looks like the only field that isn't working right is the FROM field when using a dynamic value. For now maybe just type static values for each and then edit them with the Server Behavior. I have this on my list of things to fix for the next build.
sandy170299
Got it - thank you.
