font control
Thread begun 3/05/2018 5:14 pm by software.current355386 | Last modified 4/03/2018 9:24 am by Ray Borduin | 1739 views | 3 replies |
font control
is it possible to add a font such as Segoe UI as one of the selectable font options
is it possible to set the st set the default font and size ie 15px Segoe UI.
is it possible to set the styles to ones of your choosing, if so how
If I was able to change this what would the effect be on existing pages am i correct that it would change all text automatically except were the font as been specifically set
1) There is a file: /webassist/ckeditor/config.js You can add font options there. Just add this line with the others, then you can edit it as you want:
CKEDITOR.config.font_names="Arial/Arial, Helvetica, sans-serif;Comic Sans MS/Comic Sans MS, cursive;Courier New/Courier New, Courier, monospace;Georgia/Georgia, serif;Lucida Sans Unicode/Lucida Sans Unicode, Lucida Grande, sans-serif;Tahoma/Tahoma, Geneva, sans-serif;Times New Roman/Times New Roman, Times, serif;Trebuchet MS/Trebuchet MS, Helvetica, sans-serif;Verdana/Verdana, Geneva, sans-serif";
2) You can apply a default style sheet to set things like this. Just add these lines to the editor code:
$CKEditor_config["contentsCss"] = array("/directory/cssfilename.css");
$CKEditor_config["bodyClass"] = "defaultClass";
3) There is a file: /webassist/ckeditor/style_lists/stylelist1.js You can add style options there.
believe aded ok, not showing in dddropdown font its what have I donE wrong
pm has copy of file
I'd need FTP access and a URL to reproduce to look into it.
