Selecting Google Search and nothing happens
Thread begun 11/16/2017 3:22 pm by LionsMane | Last modified 12/02/2017 1:10 pm by Ray Borduin | 1377 views | 3 replies |
LionsMane
I have the Free Tools installed, and from the menu at the top of Dreamweaver, I select "WebAssist" and "Google Search" and absolutely nothing happens. Nothing is locked up, it's just that nothing actually happens.
Secondly, I'm not even sure I have the right product I need. I want to build a search to pull back any page in the site, but am unsure if I should be searching the database by some method, or if the Google Search will work right for what I need? Most of the site's pages are dynamically populated. Thanks for the feedback.
It sounds like the secondary installer didn't complete the installation. You may need to reinstall in order to get it to work properly.
After install make sure that you open a new web page and a secondary webassist installer should run. After that you need to restart Dreamweaver one more time and the extension should begin to work.
LionsMane
But what kind of search
Thanks Ray, I'll try that again later, but I'm curious about my second question here. Should I even use this Search method on a site that's completely database driven? Or something that searches the database directly like what we did with the Med site? More info in PM
It really depends on what you are trying to do. If you have a single or maybe two database tables that have all you want to search on then maybe a simple recordset solution would be better. On this site I use the google option because we have products, forum posts, tutorials, cms content, and other content on pages all of which I would want to be found if searched on.
