Shipping has disappeared
Thread begun 9/08/2017 8:14 am by NWak04030229 | Last modified 9/18/2017 7:37 am by Ray Borduin | 6778 views | 22 replies |
NWak04030229
Couple of things: Shipping seems to have disappeared altogether from my eCart. I have checked and all the shipping options show up under eCart Object but when I buy anything from the site it does not add the shipping. I must have unticked/ticked something in error - what could I check on to see what has happened?
Also: When I go on the site and try to purchase certain items I get the following error message:
Warning: Missing argument 10 for OldTheatrePosters_Definition::AddToCart(), called in /srv/disk4/89822/www/oldtheatreposters.co.uk/s.php on line 1091 and defined in /srv/disk4/89822/www/oldtheatreposters.co.uk/WA_eCart/OldTheatrePosters_PHP.php on line 25
Warning: Cannot modify header information - headers already sent by (output started at /srv/disk4/89822/www/oldtheatreposters.co.uk/WA_eCart/OldTheatrePosters_PHP.php:25) in /srv/disk4/89822/www/oldtheatreposters.co.uk/s.php on line 1219
What has gone wrong there?
The add to cart error appears to be that you have added a column to your cart but haven't updated all of your add to cart buttons to make sure that column has a value.
The shipping I'd have to debug directly. If you give me steps to reproduce the problem and FTP access I can try to see what is happening.
NWak04030229
Thank you - details sent privately
What page has add to cart buttons that I should be looking at? I'll see why it isn't showing up in server behaivors and/or show you how to update the code by hand.
NWak04030229
It's all the pages A thru Z - if I open them up in Dreamweaver CC2017 then I open Server Behaviors nothing shows. Thanks for this just need to get the site back up and running as soon as I can. I have 2 other sites using eCart but those are functioning just fine
Please post the url to one of the pages and the exact folder where I should look for the file and I'll take a look.
NWak04030229
http://www.oldtheatreposters.co.uk/j.php - any of the add to cart buttons on there have the same problem. Is that what you meant?
The Add to Cart buttons can be opened and edited from the Server Behaviors panel. I just opened the page and I see them all there.
To edit the code manually you just need to find the add to cart code on the top of the page and add the new column value. To do that, find any line that starts with:
$ATC_itemPrice = floatval
and then add a line below it for the new column:
$ATC_itemShipFlat = floatval("0");// column binding
Then, two lines below that, you need to add the new column to the actual add to cart function like:
$OldTheatrePosters->AddToCart($ATC_AddIfIn, $ATC_RedirectIfIn, $ATC_itemID, $ATC_itemName, $ATC_itemDescription, $ATC_itemThumbnail, $ATC_itemWeight, $ATC_itemQuantity, $ATC_itemPrice, $ATC_itemShipFlat);
You can see I added ",$ATC_itemShipFlat" before the closing ")";
You would have to do that for each add to cart code chunk. I've gone ahead and made the change for the first one on j.php by updating lines 21 and 24.
NWak04030229
Many thanks - I'll go and do all that now. Does this also fix the fact that Shipping isn't coming up on the final Cart?
That should. It looks like you only charge shipping if the country is set to "GB" and there is at least one item with ShipFlat set to "1".
Make sure when you are updating the cart you set the correct ShipFlat value. If you do set at least one to "1" that is in the cart then it should charge the shipping.
