Getting 'This record has been removed' on Detail page
Thread begun 5/11/2017 10:58 am by DeanCollins | Last modified 4/15/2019 9:20 pm by Ray Borduin | 2978 views | 7 replies |
DeanCollins
Hi! When I go from a results page to the details page, I'm getting a "This record has been removed" message instead of the record details. (Also, the record HASN'T been removed, which confounds me more.)
I've got details pages galore elsewhere so this is for some reason a one-off thing.
I've attached the results and details pages in question.
It looks like some of your code on the details page got placed in the wrong spot.
Move lines 75-153 to the top of the page and that should fix the problem.
DeanCollins
Ah! Thanks! That did it.
Jonas
I also have this problem on one page (and I recognize the same problem from previous pages I created using DA). Can you please specify in more detail which lines of code to move and where.
The strange thing is that it works on some pages but not on others.
I'd have to look at the page. Try changing WebAssist->Preferences and choose "Wizard Settings" and increase the delay. Sometimes when the wizard runs too fast Dreamweaver can start behaving inconsistently.
Jonas
Can u take a look at this page (attached)?
I receive the same error message on this insert page when I register a new record. But the problem is probably bigger than that, I suspect. Because it writes nothing to the database. I have tried to do the same page several times with the help of DA. But it will be the same.
Thanks in advance!
Supplement: However, it saves the selected image, so "upload files" work.
I can't understand what the problem is. Now I have created this page ten times the least, and get the same error. I have compared to other insert files that I created with DA and that work - but find nothing strange. Can there be anything in my database? I attach a screenshot to this as well.
And the update page writes without a problem.
It looks like you have:
$InsertQuery->bindColumn("genomsnittsbetyg", "s", "", "WA_SKIP");
Which will cause it to not enter a value for that column, however that column doesn't have a default specified and doesn't allow null. You can't skip a column that doesn't have a default value and doesn't allow null during an insert.
Jonas
I didn't see that! I am very grateful.
