Update Cart not updating? Is it possible to simply have a "Delete" option next to each cart item?
Thread begun 2/15/2017 4:48 pm by Nathon Jones Web Design | Last modified 2/17/2017 11:10 am by Ray Borduin | 7117 views | 32 replies |
I'm trying to add the facility for a customer to be able to remove items from their cart. I've tried installing the Update Cart button but this isn't updating the cart. Is it possible to just add a Delete option alongside each cart item?
Will post login details and URL in next post as you can't insert private messages in the initial post on this board.
Page is attached though.
Thank you.
NJ
Log in details...
Ecart 6 has the option to add a "remove" link to the cart display. It actually has one by default that is only displayed on mobile devices, but you can update the class to always show it instead of the delete checkbox which is there by default.
Where is that option? I don't see it on the page.
It is one of the available columns you can add to your cart dispaly.
How do I add that outwith the Wizard?
EDIT:
I've created a blank page and re-ran the eCart Display Manager. I don't have "Remove Link" as an option.
EDIT 2:
Ah, found it. It was already part of the cart so, therefore, wasn't available as an option. It inserts the following on the page...
<p class="eC_ItemRemove_Link max_tablet"><a href="#" onclick="waec_update('Remove','cartDC_Quantity_<?php echo $cartDC->DisplayInfo("WAUID"); ?>',this);">Remove</a></p>
I've added this to my actual cart page but clicking it doesn't remove the item. What am I missing?
Page attached.
Thank you
NJ
You have deleted all of the class="" references from your cart display. The AJAX code uses those to find the necessary areas to read and update values. The remove link is an AJAX component and that is why it stopped working. I've updated your javascript so that it works now but it does a page refresh, which it wouldn't need to if you hadn't updated the cart html and removed the class references.
In the future you can remove the .css referencing a class, but don't remove class="" definitions from the cart because they are necessary for the mobile friendly AJAX code to work properly.
It has been requested before, but just a completely unstyled option for eCart Display would be really helpful.
When you say class="" definitions, do you mean things like:
<div id="eC_Checkpoint_test_Arial" class="eC_Display">
<div class="eC_Checkpoint_test_Arial">
<table class="eC_ButtonWrapper" cellpadding="0" cellspacing="0">
<tr class="eC_SummaryFooter">
<td id="cartDC_JSON_Display_GrandTotal">
<td class="eC_SummaryLabel">
etc?
Which is CSS and which are Definitions?
I don't want it to do a page refresh, I want it to work properly so I'm going to have to run through it all again. I must have applied the eCart Display Manager, and spent hours restyling the page to match the site, about 10 times over now.
I've created a blank page, template.php, and applied the eCart Display Manager to it. I've selected Updateable Cart and it has installed a cart with the elusive "Remove" link.
I've copied everything from that page to my actual cart page, view-cart.php, but it still isn't working. Clicking the "Remove" link does nothing.
Attached.
NJ
To get an un-styled cart, simply remove the cart .css file. Completely un-styled would also remove the mobile friendly media queries. It might make more sense to delete all but the media query portion of the .css file to get it un-styled.
All of the actual styling is done in the .css file. The class="" in the html is also used as identifiers.
I can't debug an attached page like that. I'll need a live url to view the page, since the php, html ,and javascript all work together to make a functional page. If you give me a url I can test it that way and tell you why it isn't working.
Unfortunately, it's a bit late for that because I've clearly deleted things which I've thought were just styling but were actually definitions.
http://www.dreamcaruk.com/view-cart.php
