PowerCMS Images Not Uploading
Thread begun 9/05/2009 6:09 pm by lawrence219733 | Last modified 9/08/2009 11:36 am by Eric Mittman | 2681 views | 2 replies |
lawrence219733
Has anyone run across a situation where everything works perfectly but when you go to upload images, it say your files have been uploaded, the path is correct, the image is listed in the server list, But there is a little red "x" where the image should be? Any help would be appreciated!
lawrence219733
F.y.i.
I already tried the Zip Fix, that part works fine. I actually looked in my image directory with Dreamweaver FTP, and the images have not actually been uploaded as PowerCMS had stated.
Within PowerStore this is going to be based on the local images path in the globals file as well as the root URL you are using. What are the values you are using here? The images folder will need to match up with the images folder on your site.
If you get the image with a red x you should be able to view the properties and see where it is trying to come from. This should give you a clue about the location and what would need to be updated in the paths to get the image to show correctly.
