Quick troublseshoot required :(
Thread began 12/01/2016 12:56 pm by russell298997 | Last modified 12/01/2016 2:44 pm by Ray Borduin | 619 views | 1 replies |
russell298997
Trying to complete an application form for client - at page application8.php, i have an update behaviour working, but also want this to trigger an email to client and user on form submission, before redirecting to applicationcomplete.php. I have the update behaviour first (not redirecting), then the email behaviour, redirecting to applicatrioncomplete.php, but it returns to application8.php and hangs up a blank page. Tho weirdly it worked ONCE.
Can you see whats wrong from zip file attached?
I think the issue MIGHT be to do with a couple of bindings which are in the email body (blank14.php) - I want the email to be able to include the name and address of the user, returned from rsQuest (if that makes sense.
If iy helps i can give you FTP access....be great to get this resolved beofre close of play tomoro if poss - thanks as ever.
btw - if its easier, the email could also be triggered from the final page - applicationcomplete.php - but i couldnt see how to trigger it with no form submission. is there an easy way?
webassist.zip
Most likely the issue is with an error in the email body that is causing the page to be blank.
If you add this to the top of the page:
ini_set('display_errors',1);
Then it may display the error instead of the blank page and that might lead you to the solution.
