Why am I having a problem adding two forms to the same page adding them as plugins using Framework builder.
Thread begun 11/03/2016 9:28 am by russb335115 | Last modified 11/08/2016 2:29 pm by Ray Borduin | 3942 views | 10 replies |
russb335115
I have a two forms a one page. Both are added using Framework builder plugins. The first form works perfect when I us it as a stand alone page. However, once I add it to the template page as a plugin all the validate fields show the validate error message as well as the submit button. Then I add the second form at the bottom of the page the same way. On this form the security question doesn't show up. However, the field to answer the question does. This second form is working great when added the same way on the other pages. I'm lost to what is going on. See PM
Interesting... Can I get FTP access to the site to debug? I'm sure I can figure it out for you.
russb335115
See PM
The default code uses require_once() to include the security question. That will only add it once... I changed it to require() and that worked to show the question, but it shows the same question twice which looked odd to me.
So I updated the include file for the security question to allow you to set a version and have more than one version on a page. Then I updated both of your plugins to set the different versions and refer to the correct session variables.
It should be working now. Please download your plugin files and the wavt_captchasecurityquestion.php file to make sure you have my updates.
russb335115
Thanks, that fixed the issue with the security questions. However, the forms are still not submitting. When you file out the forms on the top you still get the error fields hoping up even before you push the select button. Try to fill out the top form and you will see what I mean.
Like I mentioned earlier. the forms work great separately but when put together on this page they do not. See PM.
You have an older version of the jquery library included on your template page, which was being added after the jquery library added by the plugins and causing conflicts.
I resolved the problem by moving the older library file above the theme and plugin scripts on the template page.
russb335115
Okay so it looks like the form is excepting the information. However, when I push the submit button it shows the validation error in the answer box. I also noticed that if I'm filling in the top form and hit the "tab" key it moves to the second form.
Also, I did download all the files from the server to my desktop before view the page.
You can fix the tab problem by setting the tabindex attribute for the fields. Just leave the top form tabindex values as 1,2,3,4 and update the bottom fields to use 11,12,13,14,15
I've gone ahead and made that update for you. The validation was failing because of a typo in the update I did for you on the wavt_captchasecurityquestion.php page. I've fixed that as well.
russb335115
Ok, so fixing the forms seems to have cause a different problem. My navigation on the mobil version (phone) no longer works. Here's what I discovered. (see PM)
You have an older version of modernizr on the template. I updated to v3.1.3 and that seems to resolve the problem.
