Request Entity Too Large
Thread begun 10/10/2016 1:11 am by Kumel | Last modified 10/10/2016 5:21 pm by Ray Borduin | 7214 views | 10 replies |
Kumel
i keep getting error as such when i try uploading image:
The requested resource
/admin/edit-post.php
does not allow request data with GET requests, or the amount of data provided in the request exceeds the capacity limit.
Additionally, a 413 Request Entity Too Large error was encountered while trying to use an ErrorDocument to handle the request.
my php.ini contains this:
post_max_size = 60M;
upload_max_filesize 30M;
memory_limit = 90M;
How large is the file? Do you have method="post" in the form tag?
Have you tried using:
phpinfo();
To make sure that you max size updates are set properly?
Kumel
here is php info: http://vahancabs.com/phpinfo.php
It looks like you have:
upload_max_filesize 2M
The php.ini must not be updated properly.
Kumel
I tried uploading image with file size of 800kb i didnt upload & it was uploaded on summer note description section.
My current php.ini contains this:
memory_limit = 90M;
Kumel
is it suppose to be :
upload_max_filesize= 30M; ( there wasn't = comma earlier)
memory_limit = 90M;
Kumel
method is post. no error when images was size of 100-120kb
Did you get the same error when uploading the smaller file? Is your form using method="post"?
Ok so that is a different issue. That could be a permissions problem of some sort. We should probably work on one thing at a time so that this thread doesn't get too confusing.
The large file issue appears to be a problem with your php.ini update. You may be updating the wrong php.ini file or it may be listed more than once. The max size is still set to 2M regardless of what you think you updated it to.
It looks like there are several .ini files loaded. Maybe they are overwriting each other?
Kumel
there were multiple php.ini added. but currently just 1 is present
