datepicker -> timepicker?
Thread begun 8/08/2016 12:24 pm by Jamie | Last modified 8/10/2016 11:06 am by Ray Borduin | 3136 views | 4 replies |
Jamie
Have got an addition to an existing project where I have to add a login for staff who then access a form (linked to their ID) which they then complete their timesheet.
Couple of questions in the first instance.
1. is the datepicker limited to dates only or can it be modified to time values as we will have to have days of the week with each hving the following time info:
travel time
job start time
job end time
travel time
2. with the above in mind, relatively speaking is it 'easy' to output time sheets that have been input which calculates the total hours for the week (and prehaps breaking it down by day as well)?
thanks
Jamie
1) the datepicker is just for dates, but you can find a timepicker with jquery to use pretty easily to add time.
2) It shouldn't be too hard, both mySQL and php have date calculation functions to allow you to add and subtract dates and find the difference between them.
Jamie
thanks Ray..
So am assuming that it needs to be stored in the db as a 'TIME' datatype?
When I set up the timepicker, do I need to insert/update the input in a certain way?
You could use varchar to store the time separately, or combine it with the date to store it as a datetime.
Jamie
ok thats great, many thanks
