Server redirect not working on live server
Thread began 7/11/2016 7:49 am by Jason | Last modified 7/13/2016 9:20 am by Ray Borduin | 778 views | 4 replies |
Jason
I have a redirect that works fine on my testing server, but not on my live server.
if($_SERVER["REQUEST_METHOD"] == "POST"){
$WA_Redirect_URL "attendance.php";
$WA_Redirect_KeepQS true;
    if (
$WA_Redirect_URL != "")  {
     if (
$WA_Redirect_KeepQS && $WA_Redirect_URL != "" && isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] !== "") {
$WA_Redirect_URL .= ((strpos($WA_Redirect_URL'?') === false)?"?":"&").$_SERVER["QUERY_STRING"];
header("Location: ".$WA_Redirect_URL);
//    echo"here it is";
//    die;
I've verified that the live server is reaching that code using an echo/die statement, but for some reason it's still not redirecting. The problem page is attached.
I without looking at the code more closely, I don't suppose you checked if the file on the server is named as "Attendance.php" - I am wondering if its a case sensitive issue? Chris
Jason
Nope, it's not a case sensitive issue. Upon investigating further today, it's happening on every page that uses the server redirect code and a specific theme. I've got multiple themes, and the problem only occurs on pages that use this one. The theme is attached to this message.
alf_cms_blank.dwt.php
Looks like white space between php tags is causing the dreaded Headers Already Sent error which in turn is causing the redirect to fail.
There are multiple code blocks on your page that are indented, for example the code block at lines 87-92:
$smallgroups = new WA_MySQLi_RS("smallgroups",$local_i,0);
$smallgroups->setQuery("SELECT sg_smallgroup.* FROM sg_smallgroup WHERE sg_smallgroup.leader = ?");
$smallgroups->bindParam("i", "".(isset($user_id)?$user_id:"") ."", "-1"); //WAQB_Param1
$smallgroups->execute();
(the blank space at the start of the <php tag is not showing here, but view the original page in Dreamweaver and you will see it)
the tab that is in front of the opening php tag is writing blank space to the page, this before the header() function will cause the headers already sent error when it tries to do the redirect.
there are a few other parts of the page that have the same indenting of php code blocks.
for more details on the headers already sent error, see the following post:
http://www.webassist.com/forums/posts.php?id=19285
Jason
White space was the issue. Thanks Jason!
