how to validate a field on condition?
Thread begun 7/07/2016 1:31 am by tony | Last modified 7/07/2016 7:22 pm by Ray Borduin | 2245 views | 5 replies |
tony
Hi all,
I have a form with a dropdown menu and a text field.
The text field is disabled until I select a specific value from the dropdown menu.
When I select the right value in the dropdown menu, the text field gets enabled (I used jquery to handle enable/disable) and I need to validate it.
If it's disabled I don't have to validate it.
How can I validate the text field only if it's enabled?
TIA
tony
Are you doing client or server validation for the rest of the form?
tony
I'm doing server side validation.
TIA
tony
In your validation you can use something like: <?php echo($_POST['selectfieldname']=="other")?$_POST['textfieldname']:"n/a"; ?>
That way if the value of the select field is "other" it will validate the text field, but if it isn't it will use "n/a" which would pass validation.
tony
Hi Ray,
thanks for your patience,
where should I put this code?
what kind of validation should I select from the "validation type" list?
TIA
tony
As the validated value. I was thinking you were needing required validation.
