dynamincally add another form select after current has been populated
Thread begun 5/31/2016 1:24 pm by Christopher West | Last modified 6/01/2016 12:00 pm by Ray Borduin | 1706 views | 3 replies |
Hi, here is the scenario, In my admin, I have a 'create product' form.
On this form is a single 'category' select list where the client can assign the product to a category. So on form submit the general product data is stored in a new record in the product table, and the category id AND product id are stored in a catalog table. (So that the product can exist on many categories).
My idea is as soon as the client chooses a category from the select list, then a new category select list appears where the client can select a second category...this process repeats until the client stops choosing a category from the select list.
On form submit the 1 product record is created. and at the same time 'many' catelog records are created on how many categories the client had selected.
What would be the process for this? what type of javascript would I need to include. and is there a webassist server behavior that can help with this?
Chris
This is done by hand. You would use javascript and the document.createElement() function or maybe the cloneNode() method to duplicate the existing element. We don't offer anything to help with this.
would you not offer this as a premiere ticket? unless would it be an easier solution to do a multi-select list on the form? Ieve never tried multi select lists before and so not sure what that would work for adding multiple record inserts.
We can work on this in a premiere ticket.
