Inserting multiple records ( skip empty)
Thread begun 3/24/2016 7:07 am by Kumel | Last modified 3/24/2016 11:30 am by Ray Borduin | 2565 views | 5 replies |
Kumel
I have a form where multIple records are displayed.
its something like this form.
a (.)
b (.)
c (.)
d (.)
Each of them have checkbox. These are dynamic repeat regions.
So here, there four checkbox(s).
Currently i have added multiple record into this.
& chosen “skip if empty” then that checkbox id
Example: if i choose ‘c’ (3rd) then only that record enters.
Once after this insert record, users again comes to update certain records which shall restore & display which were checked (in this case its “c” which was checked). So this i know how its done.
So then lets say he chosed ‘c’ to uncheck it (rest untouched) so then again this must be entered that he unchecked only this particular record. This must be insert record not update (FYI)
So can there be checked value & unchecked values?
Currently checked value is 1, can uncheck value can be 2.
Well this can be repeated again to checked & unchecked again & again.
How can we achieve this?
You probably would have to delete all of the previous selections and re-insert all of the updates.
Kumel
i dont need them to be deleted. its all kinda part of storing history of it. Would this be better if i use radio group?
Potentially... since then there will always be one and only selected and each radio can have unique values when necessary.
Kumel
ok i will try..
Kumel
well radio group seemed to work. applied some php if else while inserting records.
