How to create Search/Results/Detail pages with Data Assist and eCart
Thread begun 2/17/2016 2:23 pm by tmcbinc99963 | Last modified 2/17/2016 3:23 pm by Ray Borduin | 1091 views | 1 replies |
tmcbinc99963
I have an existing Bootstrap page with Search field, plus Framework Builder themes.
How does the DA Search page integrate with an existing Search field? Does this have to be done manually?
Which wizard layout should I use for a Product Results list and Detail pages? Most of them look like admin pages. If they have to be edited manually, should I use Data Assist for this, or just create from scratch?
Can eCart be added to both the Results list and Detail page?
Will the Results and Detail pages automatically adjust when a theme is added?
I've searched the forums and tutorials, but none seem applicable.
If you have an existing Search and results page, then you can add the search to an existing recordset by applying the DataAssist Search server behavior on the results page.
Once you find the layout that is closest to the one you want you can create those pages with the wizard. Once the wizard has run you should make all changes moving forward from Dreamweaver outside of the wizard.
Yes, you can place add to cart buttons on the results and details pages.
The pages will be positioned within the theme or can be plugged into an existing template. If and how they react depends on the css and html layout you are using.
