Select all styled checkboxes - premium support
Thread begun 2/12/2016 11:01 am by iain331081 | Last modified 2/15/2016 11:45 am by Ray Borduin | 1545 views | 4 replies |
iain331081
This is something I've been looking at and very nearly got working. Basically some forms with nicely styled checkboxes, and also an option to select all the checkboxes.
I have the styling working with jquery, and I have the select all option working. Just not both at the same time.
The closest I have got has the check / uncheck all toggle out of sync - so when then 'select all' box is checked, the rest are unchecked, and vice versa.
Link below...
Yes I can figure it out with you in a premier ticket.
iain331081
Thanks Ray - not sure if you have any time today, but I'm around for the next few hours if you do.
My Skype is below.
I've added you to my contacts. Feel free to accept the request in Skype and I can work with you later today or sometime this weekend if you are available.
iain331081
Hi Ray - you are in my Skype contacts from a previous support call.
I'm around this weekend, so if you have time Skype me and I should be able to come to the computer to look at this.
Hopefully its relatively straightforward if you know JS inside out like forcing the initial state of the checkboxes.
