eCart Object error on cart page only
Thread begun 1/04/2016 1:45 pm by mrobben375515 | Last modified 1/04/2016 3:49 pm by Ray Borduin | 3337 views | 4 replies |
mrobben375515
I have an eCart Object that is not flagged on any pages with problem, other than the cart.php page only. I can't remove the eCart Oject from that page. I do see the eCart Object is called very early in the code (around line 5). I am experiencing a error box that says "Error in server behavior eCart Object: the participant's property is not an array, or the elements in the array are not nodes in the document. I am attaching the php page and credentials if it helps identify the problem.
It probably isn't allowing you to remove it because it is used in so many places on the page. You have a cart display and update, clear, and checkout buttons on this page.
Are you trying to remove all of the cart object as well as the display?
mrobben375515
When I click on the "Checkout" button on the bottom I am getting the error
"Warning: Cannot modify header information - headers already sent by (output started at /home/content/05/11651305/html/1to1-silpada/cart.php:4) in /home/content/05/11651305/html/1to1-silpada/cart.php on line 108" and I am thinking it has something to do with the eCart Object. It is also flagged as "red" in the SB box so I wanted to fix it.
The header error is just the blank line of code on line 3... if you delete that the error will go away.
The red exclamation point is just the word "Redirect" missing from the ecart redirect comment on line 105. If you add that to the end of the line the red exclamation point will be cleared up.
mrobben375515
You helped me as always! Thank you.
