Vertical Menu motion to the left
Thread begun 9/02/2009 6:36 am by Russell Collins | Last modified 9/03/2009 10:37 am by Jason Byrnes | 2488 views | 3 replies |
Russell CollinsBeta Tester
I had a look through the forum and did not find any info regarding being able to have a vertical menu that is placed in a right side column to be justified to the right and have the other levels then move to the left.
Any thoughts ?
Regards
Russell
In the Edit Menu Theme wizard, in the Dimensions Margin & Padding section, go to the item tab. You will need to negative margins on the Left margin for the sub menus. If the menu is 100px wide, try adding a left margin of -200px to the sub menu, you may need to play with this value to get it just right.
Thanks Jason,
Russ
You're welcome.
