multiple coupons
Thread begun 12/09/2015 12:55 pm by stuff223820 | Last modified 12/14/2015 4:17 pm by Ray Borduin | 1732 views | 4 replies |
stuff223820
multiple coupons
I am having a challenge getting multiple coupons to apply.
If i have coupon "1": applies to a savings if ordering multiples of a select group of products
Coupon "2": applies to a savings if ordering multiples of a select different group of products
and add those 2 different groups to a cart, only 1 coupon (discount) will show
In my cart - try selecting 3 of a coffee mug and then add 3 of a t-shirt -
https://dirtymonkeykustoms.ca
The cart is set up to only apply the coupon with the largest value if more than one coupon is used. It would be difficult to change that logic since it stores the applied discount in the order as a number field and the logic would get rather complex figuring out which combinations of coupons were possible but not overlapping to allow more than one to be applied.
stuff223820
would this still apply of the coupons are directed to 2 totally different products - 1 for shirts and 1 for mugs for example? same order
Yes. the system will only allow one coupon per transaction. It doesn't evaluate whether there is overlap or not.
We could probably get it to work in specific scenarios in a premier support ticket, but as it is the customer would have to do separate transactions to use separate coupons.
stuff223820
ok - thanks Ray!!
