coupon to discount shipping
Thread begun 12/07/2015 5:11 pm by stuff223820 | Last modified 4/05/2016 11:36 am by Ray Borduin | 4250 views | 11 replies |
stuff223820
is it possible to use a coupon to discount shipping when using flat rate shipping? Any other ideas?
Here is the scenario:
This is good:
buy 1 tshirt of design "A" = $10 shipping
buy 2 tshirts of same design = $10 shipping for first, and + $3 for second
problem:
buy 1 tshirt of design "B" = $10 shipping
(shipping is too much = $20 )
Another problem:
buy 1 tshirt of design "A" size "med" = $10 shipping
buy 1 tshirt of design "A" size "large" = $10 shipping
should be $13 not $20 based on "good" set up from above
We could help you with adding that in a premier support ticket.
stuff223820
see pm
I think we could add the incremental shipping feature in a 1 hour session. We would just have to:
1) add a column to the database to store the value
2) update the products update page to save it (optionally add it to the product insert page but could leave it only available on the update).
3) update the cart object to have a column for it
4) update the shipping charge to use it when it is available
The other issue sounds like a bug. We would investigate and fix that free of charge... it might make sense to do during the premier ticket if you go that route.
stuff223820
Oh wait I was reading this wrong.... We already added incremental shipping, you just want separate items to not charge it.
I'll need to discuss how this might work with you. We may be able to do it free of charge, since it may be a small logic update and not require additional database fields or updating any product insert or update pages or even the cart.
stuff223820
yes, the incremental shipping works great!!
The challenge is: the full shipping rate ($10) is getting added to each shirt of the same design, but when a different size of the shirt is also added to cart - when that too should be covered under the "incremental" cost of the $3 - not the full rate of $10 each for the same shirt in 2 different sizes. Maybe i am asking too much
We could probably add logic to add only the highest base shipping rate of all of the items in the cart, then add incremental shipping rates for all other items. Would that fit your needs?
stuff223820
I think that would work well - it would solve several problems with shipping and get something much more appealing to a consumer. Thanks Ray!!!!
I've added that logic... I updated the file: WA_eCart/Short_Cart_PHP.php
Please test and let me know if you find any problems.
stuff223820
seems to be perfect so far Ray!! certainly does make shipping of dis-simular items reasonable when using flat shipping rules
Thanks!!
