id showing instead of the size in cart in mysqli
Thread begun 9/09/2015 10:20 am by Dave W | Last modified 9/10/2015 1:17 pm by Ray Borduin | 1042 views | 2 replies |
Dave W
The problem is that my size dropdown is populated depening on the quantity available in the colours dropdown ( a MySQLi version of dynamic dropdowns) but, unlike the MySQL version (which passes the size instead of the sizeID) it passes the sizeID not the size and I can't figure out how to make it show the size and not the id in the cart.
I have looked at other answers to similar problems in the help section but they are all for MySQL.
I have attached both my final details page and cart page to see if that helps and also an image showing the problem.
Add a recordset to the page that does the Add to cart that is filtered by the submitted Size ID and returns the size and any other fields you want displayed in your cart.
Then you can either add another column to your cart for the Size name (if you still need the ID in the cart) or replace the binding in the Add to cart to get the size from the Recordset you created.
Dave W
Sorry Ray,
A bit thick here, don't really understand what you mean.
Where do I get the sizeid from to filter the recordset?
Update;
Sorted it Ray the code I have for the record set is:
$getSizes = new WA_MySQLi_RS("getSizes",$dbCute,0);
$getSizes->setQuery("SELECT sizeID, item_size FROM sizes WHERE sizeID = ?");
$getSizes->bindParam("i", "".(isset($_POST['eCart1_1_Size_Add'])?$_POST['eCart1_1_Size_Add']:"") ."", "-1"); //colname
$getSizes->execute();
The $_POST['eCart1_1_Size_Add'] is taken from the result of the colours recordset.
Thanks again for your help.
