The files from the _mmServerScripts folder are for the server model PHP-MySQL. Try to connect to the database using a different server model...
Thread began 8/24/2015 11:17 am by Sarre | Last modified 8/25/2015 11:33 am by Ray Borduin | 1797 views | 7 replies |
Sarre
Hi! I get this error message when trying to connect to remote host from within DW. I have tried several solutions found in different forums, like adding the www to the site definition etc. Also I have tried deleting the MM folder, both local and serverside. I haven't experienced this problem before and the error occured when adding the Webassist MySQLi server Behavior.
Anybody have any clues?
Best regards,
Chris
Please post a US phone number or Skype contact information and I can try to debug this with you in a screen sharing session.
Sarre
Thank you Ray, will post a message for you.
Have you installed the "Deprecated Server Behaviors" extension from Adobe? It needs to be installed for database connectivity to work from within Dreamweaver.
If that still doesn't work, sign up for a free Skype account and we can use that to debug the issue with you in a screen sharing session.
Sarre
It seems that extension is reffering to CC.
I have CS5 and CS6.
Do I still need to install?
Sarre
Private message sent regarding Skype
I've sent you a Skype contact request and we can continue this conversation there. You don't need to install Deprecated server behaviors in earlier versions of Dreamweaver, and we can chat and screen share if you don't have a working mic or speakers.
Sarre
Good stuff!
