How can I tell which version of eCart I used to create a site ?
Thread begun 8/19/2015 9:42 am by Dave Buchholz | Last modified 8/19/2015 12:24 pm by Ray Borduin | 3613 views | 6 replies |
Dave BuchholzBeta Tester
I have an "historic" customer ask me to take a look at their site as paypal express has stopped working for some reason but I am not sure at this point whether I used eCart 4 or 5 to create his cart and I don't want to open it up in 6 as I modified the code fairly heavily at the time.
If I can reinstall the cart extension I used then I would feel more comfortable working on it.
Regards,
Dave Buchholz
I-CRE8 Limited
tel: +44 (0)1926 817171
mob: +44 (0)7901 517007
A suggestion in the release notes section it would be useful if you added a date when that version number was released.
Also if it helps the cart files are all dated November 2012 if that helps narrow down the cart version.
If you open up the file WA_eCart/WA_eCart_Definition_PHP, it should have the version on the top of the code.
Ray,
unfortunately as you will see in the attached file there is no version number present :-(
I'm pretty sure that is eCart 5
ok, thanks Ray
