Removing fields/validation
Thread begun 8/31/2009 4:55 pm by angelo388134 | Last modified 9/01/2009 12:14 pm by Jason Byrnes | 5124 views | 4 replies |
angelo388134
Ok, I purchased this package really thinking this was a Dreamweaver extension, sadly it's not. There is no plug and play here, no interface. I had little difficulty getting the form up and running on its own page, since it would not embed in a template without completely ruining the layers.
Once I had the form configured to email me I tested it and it worked. I than attempted to remove the validation from the comments following the advice of two other threads in this forum and neither fix worked. I removed every line that was recommended for removal but still the form would not submit but instead simply reset itself. It would only send if I entered something in the comments box, no matter what I tried.
I also attempted to remove the captcha so I would only have the question (lots of people turn the other way with hard to see captchas) and again, the same situation. The form just resets. No red error line, I was able to remove that, but the form simply resets.
Is there anyone who has actually removed fields and validation successfully? Any help here would be greatly appreciated!
office172461
How to remove the captcha from Webassist contact form
See this article on how to remove the captcha:
142/
Not sure why you would remove the comment field. What would be the point in sending an empty message?
Hi office172461,
Excellent tutorial for removing captcha, thank you for that.
angelo388134,
See my post here for removing validation on the comments field:
showpost.php?p=14803&postcount=10
office172461
Thanks Jason,
I found that documenting my changes in tutorial form makes up for a failing memory. :)
I appreciate the link, it should help others as well.
