Is DataBridge 1.2.3 now compatible with MySQLi ?
Thread begun 8/13/2015 10:39 am by randyrie405335 | Last modified 8/17/2015 2:11 pm by Ray Borduin | 2029 views | 2 replies |
randyrie405335
OSX 10.10.4
DW CS6
DB 1.2.3
eCart 6.11
I am trying to build a shopping cart and have created a DW legacy connection to a MySQL database. I just upgraded to DataBridge 1.2.3 and now DreamWeaver CS6 crashes constantly when I try to use a DataAssist Pages feature. Is there a configuration I need to adjust or something that needs setting up to prevent these annoying crashes? It is the "+" button to select columns to be inserted that crashes DW whenever I click on it.
Not yet. We just made it compatible with DW CC 2015 and haven't completed the MySQLi update yet.
I'd have to debug it with you. There shouldn't be any configuration issues with selecting columns. Did you know you can multi-select columns from that interface using Ctrl+click in the columns.
It may help if you only enter that interface once per page type instead of re-entering it if you are adding a lot of columns.
