Show Region if not logged in not functioning properly on one particular iPad
Thread begun 8/11/2015 5:24 am by Justin@AdventDesign | Last modified 8/20/2015 8:08 am by Ray Borduin | 5798 views | 27 replies |
Justin@AdventDesign
I've created a web app that utilizes security assist Show Region if function to determine different levels of user login and authentication. It works flawlessly across all devices and browsers, with one exception. The client has one particular iPad, I'm told an older one, for which the Show Region function doesn't seem to work. For instance, there is a login form that is set to show only if the user is not logged in, but for some reason, that login form remains hidden on that particular device even if the user is not logged in.
I'm awaiting more information on the exact iPad version, iOS version and browser, but I'm looking for direction on troubleshooting. What sorts of functionality within the device would prevent the Show Region function from operating properly? I had thought with PHP it would be primarily a server side function, but apparently there's something else to it.
That code is entirely server side, so I can't imagine why it wouldn't be working on a particular device. It really shouldn't be possible, particularly for something that would show if you are not logged in.
Do you have an auto-login feature? Maybe they are logged in and just don't know it?
Justin@AdventDesign
Yes there is a 'keep me logged in feature', but if they are logged in, alternative content is supposed to show. Instead, it appears anything within any of the "show region" PHP code doesn't show.
It is all server side, so if you have two sections one that says "show if logged in" and one for "show if not logged in" it would seem impossible that both would not appear on a particular device, since that code and determination is made on the server and I can't imagine how the device would matter.
Maybe the fact that it displays or doesn't has nothing to do with the show if at all, but something to do with the actual HTML displayed.
If you create a copy of the page and remove the show if server code does it display on this particular iPad?
Justin@AdventDesign
Yes. Simply removing the PHP show if code wrapping the section allows that section to be shown on that particular ipad.
Justin@AdventDesign
OK, I just got off the phone with the client and we have a little new information. Up until this point it was one and only one device that had the issue. However, they just informed me that they had the same problem on a desktop PC, with one new bit of info. On both devices it happened after the client logged in, used the app, then closed the browser and later went back to the app to use it again, only to find none of the show if sections were displayed. So it appears to happen after a login and the browser is closed out and then you revisit the page. I'm attaching the page below to see if you can shed any light on it...
I'd need a url and steps to reproduce to pair with the code to see what is going on.
Justin@AdventDesign
Well, I haven't been able to reproduce it on my end. Following the exact same path as they outline, I'm not getting any problems, but see private message.
It looks like the first region is using:
"Logged in, Level 2"
and the second region is using:
NOT "Logged in to users"
So it seems like it would be possible for both to not be true and therefor no content.
If you want to make sure that one or the other is always displayed then you should be using:
and
for the two display areas.
Justin@AdventDesign
But there's a third section "Logged in but not approved" which is set to Logged in at Level 1. So whether they are not logged in, logged in at level 1 or logged in at level 2, there will be a section shown. I've tested all three states, and all three so the proper section on my system, whether users are the default level 1, level 2, or not logged in at all.
