Administration
Thread begun 8/31/2009 2:33 pm by Giovanni_ | Last modified 9/01/2009 12:04 pm by Eric Mittman | 1272 views | 1 replies |
Giovanni_
Administration
I am in the midst of using powerstore, but had an important and probably inmediate questions.
1- Can PowerStore support multiple admins? or backend users?
1a) Can that be added?
1b) How much can I edit PowerStore?
2- What would be the major drawback on editing PowerStore directly?
Thanks Guys
The PowerStore is designed for a single admin user. If you wanted to update it to have more than one admin user you would need to user SecurityAssist to generate a new user authentication login server behavior. You would also need to modify the access rules for administrator to work with the values from your new authenticate user server behavior.
As far as making edits to the PowerStore pretty much all of it can be edited, however any changes that you make to the code or functionality can affect how the site performs. If you want to make edits to the cart object you would use eCart for that. On the support page for Power Store is some guides and info on making certain changes.
powerstore/
