How to duplicate a record in MySQL using PHP
Thread begun 6/22/2015 10:49 am by Daniel | Last modified 6/29/2015 1:08 pm by Ray Borduin | 3531 views | 14 replies |
Daniel
The data assist pages have been working great and I can do just about everything I need in my database... except for one thing... I need to duplicate a record, then edit it with new information before committing it to the database. I can do this in phpmyadmin with no problem, but I'd like to be able to do it from my webpage while I'm on a particular record.
Often times I need to enter a new record where 90% of the information is the same but I just need to change a couple of fields.
Do you have any suggestions how I can accomplish this?
Dan Lewis
I think you would probably need to do a custom SQL statement to insert the repeated row and then save the inserted id. Then you can use the webassist update server behavior specifying the inserted id for the custom fields. If you have a sample page and example I could be more specific with the necessary code.
Daniel
Duplicate a record
The page I'm using to insert and update records is basically what I created using dataassist. I was thinking maybe the update form would be the best choice since it already has everything in it that I want to copy. I'll give you all the pages however because I've been wrong in the past!
The index.php is actually the search page.
Actually that is a good idea... Copy your update page and name it. allshows2_duplicate.php
Then remove the Update Record server behavior and add an Insert record server behavior. Then you can add a duplicate link to your results page that links to this page passing the ID you want to duplicate.
Daniel
Adding Duplicate Button
It worked!!! One additional thing I had to do was to copy the "Insert Button" and actions from the insert page. I've included a copy of the finished product. It works like a charm and a simple solution for anyone else looking to duplicate records! I also put a button on my details page linking to the duplicate page so I can duplicate at that point too.
Once thing I'd like to change on the results form is the Icon that represents the duplication. I made one using photoshop, I just took the details button and made a double spyglass. It looks good but I can't figure out how to get it to appear on the results page.
It looks like we are setting the background-image for the button with .css. Just find the .UpdateButton class in your form css and create a copy for DuplicateButton and then change the class on that button in the HTML.
Daniel
Changing the look of a button
I've looked around to try to fine the proper place to duplicate and change the .css but I just can't find how to do it. Could you be a little more specific on the instructions on how to change the .css for the duplicate button.
Do you have a live URL? I could take a look that way.
Daniel
I've put a message in the private message section
What is the web site url?
