Multiple update glitch
Thread begun 6/12/2015 9:29 am by iain331081 | Last modified 6/12/2015 7:03 pm by Ray Borduin | 4709 views | 7 replies |
iain331081
I think this one is mostly working. When you tick the tick box for lots of records, it updates correctly.
However, the record should probably show the tick box as ticked if it has been followed, and remain untucked if it has not.
I have attached a copy of the page and posted a link below.
Thank you.
You would have to add a recordset to get the previously selected options from the database and then loop through that to get an array of values and select checkboxes based on whether the value is in the array or not.
If you used "manage relational table" instead of "multiple insert" the server behavior should do all that for you.
iain331081
Thanks Ray - I thought I already had a recordset:
SELECT DISTINCT LodgeID, Lodge, GSG_URL, banner_image_new, Country, banner_image_new_title, photo_one, photo_one_title, Summary_2013, lodges.CountryID, UserIDIT FROM lodges INNER JOIN countries ON lodges.CountryID = countries.CountryID INNER JOIN product_users ON lodges.LodgeID = product_users.LodgeIDIT WHERE Product_Type = 'Property' AND UserIDIT <> '' GROUP BY LodgeID
And the loop, which is displaying all the records with the tick boxes.
Or do I need a second one to control whether or not the tick boxes show as ticked?
Where do I use 'manage relational table' instead of 'multiple insert'?
You would need a second recordset to only return rows that have inserted values.
You could delete the multiple insert server behavior and apply the manage relational table server behavior in its place.
iain331081
So one recordset to list all the products, and a second one to determine which of the products have the tick box ticked?
Looking at that now though - I assume the Foreign Key column would be LodgeIDPL, but not so sure about the Key Value?
Yes that is correct. The second recordset could do a SELECT FROM the inserted table so that it only returns records that have been inserted based on the checkboxes previously.
Manage relational table does a Delete of the old records, Insert of the new ones, and returns an array of the previously selected ones all at once to allow the page to act as both an insert/update and display previously selected values without having to create the second recordset.
iain331081
Sorry - last question - looking at the manage relational table behaviour, it looks like it should have two tables with an interlinking table.
In this structure there is just the main table, and the related table.
ie
table_lodges
LodgeID
Lodge
etc
and table_lodge_likes
LikeID
LodgeID
Where the link would just be between the LodgeID (PK) in the lodges table and the LodgeID (FK) in the lodge)likes table.
Should that still work?
Its 1am here, so time for bed - so thanks in advance for answering these questions Ray, and have a good weekend.
I don't think the third table is really necessary in the Server Behavior. It think it only really asks for columns from the first two, so it should still work.
