DataAssist Error when opening wizard
Thread begun 5/29/2015 10:47 am by elewis93815 | Last modified 6/02/2015 3:02 pm by Ray Borduin | 4709 views | 7 replies |
elewis93815
Hello,
We are trying to use the DataAssist Wizard to create the DataAssist pages and when we open the wizard we get an error. Please see attached screen shot. If we hit OK on the first error and try to proceed it will give another error. This is something that we really need to put in place for a client, any assistance would be greatly appreciated.
Uninstall and reinstall the extension from the extension manager. This issue should be resolved in the most recent build.
elewis93815
Hi Ray,
Thanks a bunch we did exactly that and it works fine now. I do have an issue. We haven't done a search field and results page for sometime and attempted to do one and are having trouble having the results show. www.ericklewis.net/namc/plan_room.php Currently we have the search function on this page which is also the results page but when we do a search, we are not getting any results. Any thoughts? Ive attached the files. Thanks for your help!
It doesn't appear to have added the search code to the results page at all. Please run the wizard again and save the preset. Then attach a copy of the preset to a reply and I can try to reproduce the problem here and look into the cause.
elewis93815
Hi Ray,
I believe that I have re created the results page and have attached the files. Will the preset be within the page itself? Thanks!
On the Results page:
1) Open the Data Bindings window and click the plus button... choose "Form Data" and browse to your search page to add the form data to the results page.
2) Open the Server Behavior window and click the plus button and choose "WebAssist -> DataAssist -> DataAssist Search". Use that interface to add the filter based on the submitted search fields you now have in the bindings for reference.
elewis93815
Thanks so much, everything is working great now!
On a side note, our client would eventually like to have a PDF listed on the data results that is linked to the actual PDF document. How is this accomplished?
You would store the path to the .pdf file in your database and then just create a link to the .pdf file from the returned result.
