Button to show all records?
Thread begun 3/06/2015 1:00 am by Mags | Last modified 3/07/2015 4:31 am by Mags | 2429 views | 3 replies |
Mags
In a paginated results set, how would I add a button that would give the user the choice to display all records? Reason I ask is that I'm also giving them the option of exporting the table to Excel but it will only export the page of results it's on, so I need to be able to provide the option of showing all records. Don't want to make this this default view though as there are over 3,000 records and rising daily!
I would create a separate page for this and add a link to the show all page.
Willi Schneider
Hi mwilson
I've done that a couple of times, but that requires a lot hand coding.
You would have to declare your own variable, let's say "$MyNumberOfRecords", which you could set as value of a form field or an option for a select menu and assign that to the "$maxRows_WADANameOfYourRecordset" in the DB generated php code.
Then you add a simple form containing that form field or menu and a submit button.
In your case (Export all data to Excel) it would be easiest to add a link to a copy of your list page, that just displays all records...
Mags
Thanks for the replies, sounds like I'll be doing it the easy way!
