Unable to Install PowerCMS on remote site following successful localhost installation.
Thread begun 3/05/2015 10:00 am by Mac McCarthy | Last modified 3/05/2015 3:28 pm by Jason Byrnes | 3514 views | 5 replies |
Mac McCarthy
Adding Design Extenders PowerCMS to an existing small site I was very happy to find all OK when testing using localhost.
I proceeded to upload all files to the remote host and opening the page I expected to be presented with the "Getting Started" screen when I open the first page (index.php)
But I get two warnings:
Warning: mysql_fetch_assoc(): supplied argument is not a valid MySQL result resource in /home/fhlinux159/c/camacweb.com/user/htdocs/WA_Globals/WA_Globals.php on line 41
Warning: mysql_free_result(): supplied argument is not a valid MySQL result resource in /home/fhlinux159/c/camacweb.com/user/htdocs/WA_Globals/WA_Globals.php on line 67
No database selected
I set up one "Dynamic MYSQL Conection" file for both localhost and remote during the installation process which clearly work locally. However I noticed that an additional connection file has been created called "_PowerCMSconnection" which has duplicated credentials, not sure why, but I assumed all OK. I have also double checked the credentials used in the connection files which are all good.
When I tried to use ../install_cms or ...admin_cms the both took me to the Admin login screen and then subsequently to the same errors as above.
Not sure where to go from here??
Update:
Removed txt file from connections folder and got as far as step 4of5 when I get following error:
ERROR: Failed to save the settings in the database. Please verify your database connection.
Moving forward, still need help please.
Update2:
Imported sql script .../install_cms/scripts/db.sql ad all completed, WOW I surprised myself!
However what did I do wrong with the above procedure?
No longer urgent.
No longer urgent.
it sounds like you didn't export the local database and import it to the remote site. the installation scripts creates the needed tables on the local host, if this table don't exist on the remote server, it won't work.
by running the sql script, you created the needed tables.
Mac McCarthy
Thanks Jason
I spoke to soon as I am now getting following errors on browsing to the page.
Warning: include(C:/xampp/htdocs/CamacWeb15/WA_CMS/addtosite.php) [function.include]: failed to open stream: No such file or directory in /home/fhlinux159/c/camacweb.com/user/htdocs/index.php on line 34
Warning: include() [function.include]: Failed opening 'C:/xampp/htdocs/CamacWeb15/WA_CMS/addtosite.php' for inclusion (include_path='.:/usr/share/pear-php5') in /home/fhlinux159/c/camacweb.com/user/htdocs/index.php on line 34
I have checked that addtosite.php has been uploaded.
it looks like you had Dreamweaver update some of the file paths to use your local path instead of the original relative path.
you should upload a fresh copy of the files.
Mac McCarthy
Jason
Fresh copy uploaded and all working as expected, thanks for your perseverance.
Mac
you're welcome.
