$WA_fieldNamesStr
Thread began 2/25/2015 9:09 am by charles164095 | Last modified 2/25/2015 9:29 am by Jason Byrnes | 658 views | 1 replies |
charles164095
$WA_fieldNamesStr
How do I modify a WAUpdate so that I can add a variable to the argument $WA_fieldNamesStr = "xxxx"; I would like to insert a column from a recordset into this field to modify which database column I'm sending this info to..
Something like: $WA_fieldNamesStr = "$row_rs['qs_ordr']"; with how to get the $row_rs['qs_ordr'] correctly into this row.. Sorry that my terminology is jumbled..
Thanks in advance
don't edit the code, instead edit the server behavior.
open the server behaviors panel, in the list of server behaviors for the page, double click the update record server behavior to edit it.
on the bindings tab, select the column you wish to edit, then click the lightning bolt next to value to select the dynamic binding to use.
