JavaScript Error - does not complete the checkout build
Thread began 2/22/2015 6:33 pm by David | Last modified 2/24/2015 6:46 am by Jason Byrnes | 1320 views | 5 replies |
David
I have eCart 6.1.0, Dreamweaver CS4, and have built a cart with 19 columns and placed the cart display on the same .php page as the input and it works perfectly. Now I attempt to use the checkout wizard and get the following error.
While executing timer in WA_SiteTools_ProgressV2.htm, the following JavaScript error(s) occurred:
At line 415 of file "C:\Program Files (x86)\Adobe\Adobe Dreamweaver CS4\Configuration\Floaters\WA_ProgressV2\WA_ProcessingObject.js":
ConfirmPage is not defined
Needless to say when I click on checkout on my cart on my testing server it gives me a checkout.php page which is not properly formatted and it is incomplete. There is no where I can go from here.
I've attached a Word.doc that shows the error and the checkout.php page.
I have cleared the Dreamweaver cache and reset my views (seemingly common fixes) with no help.
Dreamweaver error.docx
I think this is a bug that was fixed in a hot fix of eCart 6.1.0.
Close DW, then open the extension manager, install eCart then install it again, when you start DW, it should launch the WebAssist installer to complete the installation and install the hot fix updates.
make sure to delete the existing checkout pages before running the checkout wizard again.
David
Jason - you said: Close DW, then open the extension manager, install eCart then install it again...
Did you mean: Close DW, then open the extension manager, uninstall eCart then install it again...
Or am I to install it twice in a row?
Yes, i meant to uninstall it, then install it again.
David
Jason,
Did the re-install and it seems to work properly now. Thanks for your help.
you're welcome.
