datepicker and action buttons at bottom of cart (Continue Shopping, Clear Cart, Update, Checkout) not working
Thread began 2/05/2015 7:47 am by marsha431457 | Last modified 2/06/2015 9:05 am by Jason Byrnes | 2181 views | 13 replies |
marsha431457
No matter what date is chosen, it shows up as 12/31/1969. How do I fix that?
Also the action buttons at bottom of cart (Continue Shopping, Clear Cart, Update, Checkout) do not work, they go back to the form page. What needs to be done?
http://www.bandofhonor.com/bracelets_aluminum.php
in the eCart object what is the data type for the Date column? the date picker is passing the date as a string, so the Data Type for the Date column should be text.
for the issue with the buttons on the cart display page, I will need to see a copy of that page to investigate the code.
marsha431457
cart_static.php attached
cart_static.php
your cart display page has a validation server behavior on it still for validating the add to cart button. it is trying to validate the add to cart button one the checkout and other buttons on the display page are pressed.
remove the server validation behavior from the cart display page.
marsha431457
There is so much stuff in there I am not sure what to remove. I had previously restored to an older version and thought they were gone. Can you tell me exactly what part of the source code I need to remove? Is it listed simply as WA Server Validations in the Server Behaviors window or are there other things in there that also need to come out?
on the page you sent, the server validation code is at lines 10 - 29:
if ($_SERVER["REQUEST_METHOD"] == "POST") {
$WAFV_Redirect = "bracelets_aluminum.php";
$_SESSION['WAVT_cartstatic_769_Errors'] = "";
if ($WAFV_Redirect == "") {
$WAFV_Redirect = $_SERVER["PHP_SELF"];
$WAFV_Errors = "";
$WAFV_Errors .= WAValidateRQ($boh->DisplayInfo("Color") . "",true,1);
$WAFV_Errors .= WAValidateRQ($boh->DisplayInfo("Size") . "",true,2);
$WAFV_Errors .= WAValidateRQ($boh->DisplayInfo("LogoLeft") . "",true,3);
$WAFV_Errors .= WAValidateRQ($boh->DisplayInfo("LogoRight") . "",true,4);
$WAFV_Errors .= WAValidateDT($boh->DisplayInfo("Date") . "",true,"\b([12]\d|3[0-1]|0[1-9])\/(1[0-2]|0[1-9])\/\d{4}\b","","",false,".*","","",true,5);
$WAFV_Errors .= WAValidateRQ($boh->DisplayInfo("Inscription1") . "",true,6);
if ($WAFV_Errors != "") {
PostResult($WAFV_Redirect,$WAFV_Errors,"cartstatic_769");
marsha431457
Pretty much what I thought but wanted to be sure! Thank you!
you're welcome.
marsha431457
OK, the datepicker is still not working, although I changed the field to text in the cart object and uploaded the WA eCart folder.
Also: filled out bracelets order page and submitted to empty cart. Cart was correct in all respects BUT when I clicked the "Continue Shopping" button i got this error:
Warning: Cannot modify header information - headers already sent by (output started at /home/content/04/8238804/html/cart_static.php:11) in /home/content/04/8238804/html/cart_static.php on line 831
the error on the cart display is probably a blank line between php code blocks where the server validation code used to be.
